Enclosure with Air Purge Regulator
JRoss
Sep 2006
Dillsburg, PA
184
Hey everybody. I am doing a proposal for a customer, and one of the requirements he's given me is for a "NEMA 12 panel with air purge regulator". I've asked for clarification, but from my searches, it looks like air purging of an enclosure is related to explosion proofing. Any ideas? Any product suggestions?
Thanks,
Jeremy
Is the panel for a hazardous area (gas or dust) or are they just trying to keep the inside of the enclosure clean? If the panel is going in a hazardous area you should have designations like "Class I, Division 2, Group D" listed.
Panel purge kits for this type of application can be purchased from Bebco (now pepperl-fuchs).
A purge/relief system like above is a good idea; believe it or not, inert gas or air purging of enclosures can actually be tricky.
Even when using a premade purge system, I still insist on installing a low pressure blowoff device on the enclosure to prevent too much pressure build up (usually 2psi or under).
Over the time I've been hanging out on here I don't recall this coming up. How many people have air sol. valves in a cabinet? I'm sure there are...
19
4,167
I need an enclosure for wifi access points that will be outdoors. The antennas will mount outside the box but everything else inside. Standard...
160
Hello all, I have a question and would like a few opinions if possible. 5x 480 outlets control 5 machine. I want to run them through a contactor...
182
Looking over the technical data for a PowerFlex 755 & noticed they specify a minimum enclosure volume for their drives: (1)When using a circuit...
553
We am planning to build an electrical enclosure on the manufacturing line. The only concern is to prevent dust from getting collected inside the...
2,068
