PowerFlex 750-Series Minimum Enclosure Volume?
Tip DS
Aug 2023
The Great Meme State
Looking over the technical data for a PowerFlex 755 & noticed they specify a minimum enclosure volume for their drives:
(1)When using a circuit breaker or time-delay fuse with a drive installed in a ventilated enclosure, the enclosure volume must be greater than or equal to the minimum volume specified in this column.
(2)When using a Manual Self-Protected (Type E) Combination Motor Controller, the drive must be installed in a ventilated or non-ventilated enclosure with the minimum volume specified in this column.
Anybody know what this is all about? Why do they care about the enclosure size only when using fuse/circuit breakers AND only when that is done in a VENTILATED enclosure?? Is the first note completely inapplicable for an unventilated enclosure?! Why or why-not?
Do the minimum enclosure sizes multiply with the number of drives installed, or is it without regard to the number of drives installed?
Anything you guys can do to shed a little light on the reasoning behind these requirements would be greatly appreciated.
I keep getting a Net IO error message F037 on a brand new drive and after researching it, AB says that it has to be connected to a managed...
2,280
Hi, I need some help on how to reset fault on the Powerflex 750 via ladder logic. I have looked through the parameter documentation and I...
9,610
Hi everyone, I have this issue with a PowerFlex 755 that it mount a Safe Speed Monitor option module. Frequently, while running, appear the error...
2,335
Hi, I am just starting with the drives and I have a Powerflex 750 drive which is missing the rating plug board from the inverter board. I check...
665
Is anyone else having looooong connecting times when using CCW to a 750 via a 1203-USB? It is taking upto 10 minutes to connect to drive or...
1,786
