Error creating activation file when transfering
nathan.slade
Mar 2010
n.s.w
69
Hi all.
I have had to back up and reinstall our rs500 and format our laptop and when i go to reinstall the activation files from the master disk i get "Error Creating Activatin File" when trying to move from the master disk to the hard drive on the laptop. I am useing evmove v4.7 32bit if this helps. And no we don't have a service contract with rockwell at the moment.
Any help would be great.
if moving from computer to computer via a flash drive EVmoveCF if you have the master try making an ISO using RockwellMasterdisk(do search on web non Rockwell)then copy using Diskfactory 32
Hi all.
If any Rockwell applications are running you can't move the activation. Verify that no RA apps are running including RSLinx.
I know this is OLD but this may help others
I was getting this same error with no Allen Bradley
software running. The fix for me was to log in to
Administrator account and it worked.
Hi, I've been using FactoryTalk Machine Edition V11 to create runtimes for countless HMI's at versions between 5.1 - 8.2 for several months now...
17
8,327
I am running into a problem creating the runtime for a project I am working on. It will run no probem via the running man and play buttons...
3,728
Hi I am trying to retrive RSLINX data from c#.net application. I have refenced my .Net application to Interop.RSIOPCAUTO.dll. But when trying to...
2,590
We are getting this error on window manager startup error creating the instance of the intouch tagdictionary tried:- Start\Run\regsvr32...
1,822
I'm trying to create an analog tag to read a signal in Rsview32 from an analog input module but after configuring it and giving it the PLC address...
6,173
