error message when PVP screen startup
jugenzhu1963
Jun 2006
toronto
72
Hi
I have a problem with PVP screen. After I download the mer file during the screen start up there is message pup up said "there is unsupported communication protocol. Do you want to continue?" If I hit yes screen can start normally. But every time screen restart this message will pup up again. This happened on screen with firmware version 8. I also noticed under network and communication section there is LDAP configuration protocol that is not showed in version 7. Is this the problem? How can I fix it. I called AB and the guy let me setup the LDAP or reset the screen to factory default. I don't have this problem on screen with firmware before 8. Hope someone here can help me out on this issue.
Are you using any Kepware drivers, or anything unusual to an A-B controller ?
Which controller(s) are you communicating with ?
Which exact model of PanelView Plus is this ?
The screen communicate with ML 1400 Plc only with Ethernet driver. There is no Kepware driver setup. Screen is panelview plus 6. Part number is 2711P-T6C20D8.
Hi guys, I have the same program in my CPU and in my SD card but when I boot from the SD card I get error message 2400 which relates to some...
608
Good day I would be so glad if anyone can assist me. I have a message instruction and i am sending data between 2 PLC's. The Message...
3,234
I have uploaded a file from a panelview and i get a message when trying to restore it: "This runtime application file was saved in a protected...
1,376
I have been working on creating a subroutine for my company to send an email from my controller to our email server and had been successful in...
2,446
I have a 1756-L62 that is sending a message to give a 1769-L24ER a permissive bit to run. This system has been working fine for about 2 years...
3,886
