GX Works 2 error message 2400 when botting from SD card
Tjkeets90
Mar 2018
England
39
Hi guys,
I have the same program in my CPU and in my SD card but when I boot from the SD card I get error message 2400 which relates to some missing parameters but I'm unsure on what I'm actually missing.
Why would it work fine from the CPU but not the SD card?
Any pointers on how to get around this issue without leaving the SD card out?
Check the PLC Parameters folder on the PLC versus the project on the card.
I have never used the card so not sure if the PLC Parameters are stored on there, if not then it is possible that the program on the card is trying to access perhaps a file that does not exist in the PLC parameters
I'm pretty sure it relates to file registers that do not exist on the SD card or the file name is incorrect or perhaps there is not enough room on the SD card for the configured size.
Thanks for the reply Parky,
The programs are identical. I have formatted the SD card and then written the new program down.
I can't work out why it runs okay from the CPU but not the card.
Perhaps the program is but it seems to suggest it is something to do with a file register check your PLC parameters, have you got a file configured
Hello all, Does anyone here has an error codes list for that CPU? B&R CP60. This is older than 1995. The codes that appear in the status...
2,410
Hi, I am using GxWorks2 for PLC programming and configuration. I have 47 routines in my Program. After build I am getting following error. Please...
3,830
3,107
Dear Friends; I have been working with RS View32 for designing an HMI. When I write the expressions mentioned bellow, system doesn’t accept and...
1,956
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
29
