error while cross referenece generate S7 project
harrydeharry
May 2008
Delhi
237
in one of my S7300 project when I am trying to generate the cross reference it gives an error " unable to setup connection between the two objects.
Thanks for help
Regrads
Harry
Save as and mark the slow thing.
You can't walk away. If you used different versions of simatic or wincc (flexible) before in your project and never dit this before. Simatic manager gonna ask you some question.
I don't know that it gonna fix the probem.
But i think you have a good chance.
Does it happen for any STEP7 project ?
If so, reinstall.
Or does it only happen for one project ?
If so, delete the cross reference and generate the xref again.
If that does not help, try to reorganise the project, and generate the xref again.
go and find the S7xutapx.exe
Mine is under c:\Program Files\Siemens\Step7\S7XUT
If you double click this exe- Does the cross reference program run??
If so browse to your project
What happens??
Hello! When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer. When checking the buffer, it says...
212
Hi all, I am getting a Fatal Error of 0xc0000005(-1073741819) While installing V21.03 on Computer(please refer to the attachment ) please help
1,795
Respected Members; I installed Studio 5000 version 30 and RSLOGIX version 13 to 20 on my machine. I restore my computer system image two days...
1,343
Hello PLC expert i need your help. i want to use OPC communication and Matlab to read and write data from/to a Logix5561. A Topic is...
1,659
I am trying to Install RSLinx Classic Lite on a remote machine so I can use the Clock Sync Tool, But I keep getting this error. Error 1320.The...
8,188
