Hi
I using CPU 315-2DP in my project.There are 8 ET200m connected to this CPU.The central rack has a 16ptI/P card and a 16ptO/P card.
Each ET200M has 32ptI/p and 32ptO/P card.
I am using STEP7 V5.3+SP2 for ladder programming.
I get a error D280(error while compling so cant copy block) while downloading my program to the PLC.
My program has an OB1 which calls different functios.
I created a small program to test with 1 function called by OB1 still i have the same problem.
I compiled my program also.there is no error generated.Only when i go to download this error is generated.
While troubleshooting I discovered that when I use I128.0 onwards in my program this error is coming.
My IO addressing is from 0.0 to350.7
Can somone tell the reason for this error.
Why I am not able to use I128.0 onwards in my program.
Also need to know how to give IO address for distributed IO.
Annie
Annie
