Errors connecting to DL05 PLC
schechter
Jul 2011
Ohio
I am new to PLC's and am having trouble with the most basic step, connecting to my PLC. I am using a DL05, and Directsoft5 software (free 100word version).
After wading through a few other errors, we are now consistently getting the following errors.
- Support for the PLC type specified in the link is not installed.
- Comm error unlocking PLC; Data Error
Has anyone had experience with these errors? Any advice on troubleshooting?
First, check to make sure the Comm port you want to use is not being used by some other program. Hopefully, it is a Real physical RS232 comm port, not a USB adapter. I've never tried to use the ethernet port, so, I can't help you there. Next, test your comm cable if possible, on another setup. Next, delete the current link you are trying to use, hopefully, you only have one link. Then, you can start over. Here are some of the primary how to steps to establish comms with the PLC. Using the DS5 program Software, Click on DSLaunch , then Click on the DirectSOFT32 Program, then Click on the New Project box, then Click on DL-05 plc in Type box, Type in a project name in the New Project Name box, then Click on PLC tab, then Click on Connect box, a Select Link box pops up, Click on Add button or Link Editor button, follow the choices from there.
If this is the first time you have ever connected to the DL05 then use Port 1 on the PLC it will always be configured for K Sequence and 9600 baud and the device ID is defaulted to 1. Port 2 is probably not configured yet.
Connected
After several inidcations that the USB -> Serial connectors would not work, I located another PC with a serial port built-in, that did the trick. My PC gave me every indication that the USB/serial adapter was working, but it simply would not connect.
Now I just have to figure how to program this things...
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
Hi, I'm trying to add ethernet modules to one of our plcs, but I get about 15 errors that say "Invalid Signature. Reseal instruction to resolve."...
322
Hello, I have a problem with an error that appears when I load the software on the PLC. I'll attach a picture of the error window, but basically...
378
Hi! I'm newer to PLC stuff as it seems to come up at the worst possible times at work. We have an old SLC5-04 connected to a Panelview 900. Over...
781
