errors on c200hs omron
sola1957
Jan 2005
fl
I am getting a fatal error code on this plc and I know there is a bit I can turn off to clear this can anyone help. I have a factory down because of this . Thanks David Kramer
David,
What did the error log says specificaly.
I am not well versed in Omron, but I think fatal errors maynot be able to overide by users. If not why they classify it as "Fatal"
If you give more details maybe, Jay Anthony, Bob or many others here can help.
Regards
If you have Syswin or CX-Programmer software and the correct interface cable, you will be able to read what the error is in the software.
You cannot clear a fatal error if it is current, but if you know what the error is (from the above) it will allow you to fix the problem and then you can clear the error.
It is also possible with a hand held programmer, just more difficult.
Do you have the software and interface cable to read what the error is? If so, what error does the software report?
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
290
Hi, I'm trying to add ethernet modules to one of our plcs, but I get about 15 errors that say "Invalid Signature. Reseal instruction to resolve."...
342
Hello, I have a problem with an error that appears when I load the software on the PLC. I'll attach a picture of the error window, but basically...
383
Hi! I'm newer to PLC stuff as it seems to come up at the worst possible times at work. We have an old SLC5-04 connected to a Panelview 900. Over...
787
