ET 200S communicate with ET 200M
hilos
Jan 2014
Pancevo
25
Dear Coleagues,
Could you help me with next question:
Could I connect ET 200S CPU IM IM 151-8 CPU PN/DP (6ES7151-8AB01-0AB0) with DP master interface module (6ES7138-4HA00-0AB0) AS MASTER UNIT with ET 200M CPU IM 153-4 High Feature for ET 200M, PROFINET IO AS SLAVE UNIT.
Thank you in advance!
You write "for ET 200M, PROFINET IO AS SLAVE UNIT".
If the ET200M rack has a Profinet IM module, then you can connect it as Profinet IO Device directly to the IM151-8 as Profinet IO Controller by its integrated PN port.
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
119
Hi Does Siemens supply images for mmc's that have been accidently corrupted or formated?
90
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,835
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,107
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,446
