ET200 Subnet mask change
hmmm... I have connected it to my master switch with a different subnet mask and it did not update it.
I compiled all and it is still not correct
anything else I could try?
have you downloaded new config?
Not yet, do not have hardware yet. It is offline config only so far.
@JesperMP
Thanks I have set up IP and subnet mask on my PN controller config.
Still have not changed anything but it is me doing something wrong I guess...
I will have a play a bit and maybe will sort it out. It cannot be that hard :D
I think that the Subnet and Router settings in the IO Devices are syncronized to the IO Controller, even if it does not appear so in the dialog.
In TIA V15.1 I have a setting for each device "syncronize router settings with IO Controller". It is set by default, and the subnet and router settings of the IO Device mimic the IO Controller. I am guessing this behaviour is the same as V14, you just dont have the option to clear the "syncronize router settings with IO Controller" setting.
Another observation. In your picture, above subnet mask you have it set for Not Networked, add a new subnet then subnet mask is available.
No, he should not add a new subnet. He should assign the IO Device to the IO Controller.
It then gets connected to the existing network as the IO Controller is connected to and gets its other parameters from the IO Controller.
Anyway, he probably has gotten past that already.
Hi I have a task to change a controlsystem on a plant. The existing PLC is a Siemens IM 151-8 with a profibus mastercard 6ES7-138-4HA00. My plan...
630
Hi, I'm thinking of using the ET200 ECO PN system on an upcoming project. What is there to consider when using this? It seems pretty straight...
1,757
Hello, We have the following siemens DI Card 6DL1131-6BL00-OPH1 ( 32 channel) my question is in relation to the wiring of this card with the V50...
887
Hi, I have a question regarding the DI module 6DL1131-6BL00-0pH1, i am confusing myself with the family of IO, this is a 32 channel module. Can...
989
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,483
