ET200S on Profinet
Revver
Apr 2011
Northampton
22
Hi
I need to configure an ET200s on profinet, i have a 315-2 PN/DP CPU, i have gone into the hardware configuration and opened the PNIO properties and created a new network using the default IP address, when i click ok on the PNIO properties box i don't see the Ethernet network to add the ET200S to. I have a profibus networked configured as well and i can see that network.
Can you help please?????
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,108
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
119
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,835
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,447
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,208
