ET200S Profinet GSD file
psycho1o1
Nov 2021
Kaduwela
49
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is IM151-8 PN/DP. Please note that I don't have access to original project files and currently working on a upload of the program. Can anyone point me in the direction where I can download this.
The GSD file "GSDML-V2.1-NDC-710-20101220.xml"
is missing.
IO system: "PROFINET-IO-System"
IO device: "mm710e01"
my order ID is 6ES7151-8AB01-0AB0.
Thank you:p
Search for part of the file name and start down the rabbit hole.
The search, if accurate, indicates that you may have NDC 710 series gauge, whatever that is. If correct then you will need to search their site (good luck) or contact them for the file.
I cant find any reference to "NDC 710 series gauge" in the internet whatsoever. I have been stuck on this problem for weeks. All the profinet GSDML files in the Siemens support doesnt have V2.1.
Does any of this ring a bell? What kind of machine is it?
Note: The word "this" in the above question is linked to a search result. Click on it.
Hi I need to configure an ET200s on profinet, i have a 315-2 PN/DP CPU, i have gone into the hardware configuration and opened the PNIO...
1,850
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
131
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,844
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,452
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,209
