ET200S SSI module external fault
Edric
Mar 2008
Shanghai
Dear All,
Now I have a et200s ssi module for a absolute encoder to position a roll up/down movement. But now the SF light on the card sometimes will on and a fault shows in the module information: external fault, channel organized double word by double word. Any body have the same situation before, as I really have no idea about this. The code which use the input(PID 1050) as following:
A "MP_to_Degreasing".Calib_Encoder_BruRoll2_1
A "Control_Voltage_ON"
JCN a
L "PID 1050"
T "Degreasing_to_MP".ZeroPos_BruRoll_1_PV
a: L "PID 1050"
L "Degreasing_to_MP".ZeroPos_BruRoll_1_PV
-D
DTR
L "GenVal".Conv_Factor_BR1_CS2
*R
RND
T "Degreasing_to_MP".Posi_BruRoll_1_PV
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,822
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,082
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,408
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,201
