ET200S Testing a serial 1SI card
userxyz
May 2002
any
2,768
I need to test a scanner connected via RS232 / ASCII on a ET200S 1SI CP card. After downloading the hardware configuration I have fault leds on the PM and CP. There isn't any diag info in the hardware config online. Is this because I have to wire 24VDC to the PM modul ? I Guess that is the problem, but I'm not sure.
Kind regards,
Combo
Connected
Okay, connected 24V on pin 2 and 3 of of the PM, all faults gone :).
Pitty that the online hardware config doesn't show this.
Kind regards,
Combo
hi folks I saw a free software from siemens that you can test a et200s. for example you add IM moudle ,digital and analog moudle ,terminal...
4,842
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
116
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,830
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,093
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,430
