Etap
AB has the concept of a Device Level Ring (DLR), where you can connect Ethernet I/P devices in a ring topology. In order for this to work, each device needs Ethernet ports that are designed to be connected in this way. Not all devices have 2 ports, so they make an ETAP for this case. The ETAP has the 2 ports, which allow it to be connected in the ring, plus the 3rd port for the device.
A switch would consider the ring topology of DLR a loop. You could configure a managed switch with STP to allow for that or you could mirror a port, either of which then blocks the ring topology from working.
Even if that would work your managed switch now is as expensive as an ETAP but introduces more complexity and management into the network.
ETAP is a single purpose promiscuous tap so it has its place in the universe for older gear that needs to have redundant network connection.
ETAP is not just another 3-port switch!!!
DLR is using a completely different ring protocol than the standard STP or RSTP.
The problem with standard ring protocol is that they are too slow for industrial applications. It's not just Allen Bradley either. If you buy a N-Tron or Hirchmaan, they also have their own proprietary ring protocol. Therefore you have to match the type of switches carefully.
If you opt to use standard Cisco switch and do redundant ring or redundant star configuration. You have to carefully plan out the routing scheme. Often this will involve using ether-channels. You can't just plug multiple cable/fiber together and expect things will work out. The problem is, often they do "work" until a power bump and all the switches started to broadcast at the same time. Yes, I seen that scenario more than once.
Be careful using these. I was just told by AB that is giving the blessing on a project I have coming up that the ETaps are causing problems when you use VLans and a 3 layer switch. So if you have those in your system, watch out.
Are you talking about KB 631448?
Basically it says ETAP doesn't support trunking. However, this doesn't mean the DLR can't be part of a VLAN, just means ETAP can't combine bunch of VLAN together.
Hi Guys, Another thread with 5400 switches and ETAPs. See below the current architecture. I have 6 remote IO boxes, each with a pair of...
20
3,148
Hello, I have an application where I want to make a DLR where part is done in Fibre (using the Flex5000 SFP adapters, ETAP-2F for 1719 IO...
1,496
Greetings, I have a network topology that is using 5 Stratix 5400 switches that has 2 separate DLR networks configured. The DLR ports are set to...
5,064
Hello all. I have a CLX redundant chassis set up using a pair of RM and CN2R modules, and a pair of 1756-L62 controllers (basic layout stuff for...
4,162
Hello. I am setting up my second Device level Ring. Presently I do not have a physical ring. When I plug inmy last remaining ENET cable all of my...
2,386
