Ethernet Communication Omron <-> S7
Shoop
Jun 2002
NL
18
We have a Client with a Siemens S7 317 CPU and a Omron CS1 CPU.
Both PLC's have a Ethernet card connected to it.
We would like to get some data transferd between these 2 PLC's via ethernet (TCP/IP). Preferably directly between the PLC's and not via OPC.
Is there some who has done this and how, I was thinking of using AG_Send/Recieve on the S7 side. But is there something similar on the Omron side?
Also I heared about Gatway Configurations.
If anyone has an idea or has executed this kind of communication. please let me know.
Thanx in advance.
Which TCP/IP for Both ?
Dear Shoop,
Ethernet protocol, or any protocol as i understand, generally stands on OSI model.
Well when I read it last it was a "7" layered Model;) , available as a optional configuration for the implementers (PLC manufacturers or others) for their various protocols.
Sorry, my English is very poor.
Those (OSI Structure) being : (Any one Please correct me where ever i go wrong )
1) A- Application Layer -Top most layer
2) P- Presentation Layer (I guess for encryption)
3) S- Session Layer
4) T- Transport Layer
5) N- Network Layer
6) D- Data Link Layer ( I have some confusion about this layer.
7) P- Physical Layer (Hardware medium)Like Ethernet, RS232, 485..
Now TCP/IP is basically a 4 layered STRUCTURE (I have forgotten all, but I guess I am correct)
Each PLC has its own Application Layer for Standard implementation of TCP/IP. Thus to my knowledge you can not connect the two TCP/IP Protocols from different PLC vendors directly on the same backbone and conduct communication without any Gateways in between. Open standards for all PLC vendors for TCP/IP I guess is on its way soon. (Someone please correct me here).
Gateways are many...
You could try HMS (From Sweden) They give many such solutions. I hope someone else gives you more details on other such gateways.
Regards
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,612
Good day All :-) I am using a Micro850 Allen Bradley PLC which must communicate and share data via Ethernet to a OMRON CJ2MCPU32 PLC. I...
4,319
Hi, I have facing a problem when i tried to link NS15 touch screen with CJ2M with built in ethernet port. The following address i have set...
8,873
Hello, We have to create a communication between Cimplicity V8.0 (PC W7 64 bits) and an OMRON CJ1 PLC with Fins Ethernet Protocol. We've tried...
5,743
Hi We have a PC application that uses Pyramid driver to connect to Controllogix PLC using EthernetIP. It uses Class 1 communication for the...
5,952
