Ethernet connection with computer
hoejinkim
Aug 2012
Oregon state
23
:site:Hi I am struggling to connect PLC to computer through the Ethernet.
I have H2-ECOM 100 ethernet port and Direct logic 205.
Would you advice for this? what kind of parts or machine do I need or how to connect by using specific way?
I followed that way but computer didn't detect Ethernet address when the cable is connected b/t computer and PLC. Do I need machine b/t com. and PLC or specific cable
If you are directly connected you need a crossover cable, but if going to a switch then any ethernet cable will work.
Make sure your ethernet address for the PC is in the same subnet and IP range and that IPX protocol is active.
Then you should be able to go to NetEdit in your directsoft software and see the ECOM card. You can then assign a unique module ID and IP address.
In general if the ECOM is going to be assigned an address by DHCP or is static and is say 192.168.1.xxx. You want the PC IP to be in the same range i.e. 192.168.1.yyy.
Hi, guys, how’s going? We get one SIMOTION D435 machine. The communication between D435, PLC and HMI is built by Ethernet cable. (D435 IP...
4,927
Hello guys i'm working with an s7 1200 plc with an ET 200S expansion module. The problem is that i can't find the plc when searching in the...
60
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
483
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
272
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
140
