Ethernet Drive Control
shahn4
Feb 2003
Georgia
104
Does anyone had a practical experience with controlling AB Flex 700 drives on Ethernet through Control Logix plc?
I am working on job involving 20HP, 150HP (100HP Future), a panelview plus and two logix processors on a switch.
Is it worth trying without getting bog down?
I would GUESS that the system would run ok, especially if you use a decent Ethernet switch, and not some $200 cheapie.
It is interesting to observe that if you were asking the same question about a ControlNet setup, someone could give you a deterministic answer....but with this setup there are too many bits of string of unknown length.
I have used the Flex 70's on Remote I/O very sucessfully...I am only controlling airlocks and powder flow via PID loops on PLC 5.
If you are using these drives for Motion control, I would be a bit worried as regular ethernet is not deterministic... little collissions will delay reactions...
My original plan is to use DC AB 1395 through remote I/O and 1395 don’t have Ethernet.
However I am planning to use panelview plus with Ethernet capabilities with control logix processor. I thought perhaps using flex700 will save me remote I/O and I could talk to drive through Ethernet.
Since these two drives follow one another, I am skeptical about trying Ethernet. With exception of E-Stop, I would like to use all other discrete I/O’s on either remote I/O or Ethernet.
Hi All, Tearing my hair out! I have had this working in the past but cannot figure out what is wrong now! Simple set up. PF 525 set up as...
4,127
Hi all. My experience is using Studio5000 / RSLogix5000 to program CompactLogix PLC's. I need to use a basic (cheap) PLC to get data from a...
2,026
Hi.We setup S7-300 pn/dp cpu and Control tecniques emerson unidrive m200 series on ethernet.Installed gsd file communication ok.I selected input...
2,569
I am looking for some suggestions on good Ethernet/IP servo drives to communicate with an AB PLC. My customer has a non motion PLC but wants to...
1,189
Are there any documents that describe how to read/write (control) Invertek VFDs via Ethernet/IP from a ControlLogix PLC? If there are AOP (add-on...
2,306
