S7-300 pn/dp ethernet communication Control tech.drive
tulip
Oct 2005
ist
236
Hi.We setup S7-300 pn/dp cpu and Control tecniques emerson unidrive m200 series on ethernet.Installed gsd file communication ok.I selected input parameter 4 times user defined 32 bit read and output parameter 4 times user defined 32 bit write in flexible modules.Assignment adresses from 256 to 271 in hardware config.windows.Everythings were seem good.When I write FC100 inside a program like this,
L PIW256
T DB100.DBW0
L PIW258
T DB100.DBW2
etc...(ıt is calling OB1)
When I want transfer FC100 to plc ''unable to block transfer message is shown.
The other question must I use SFC14 and SFC15 blocks for ethernet communication?Thanks in advance...
Copy the blocks from your project into a library and then post the archived library. It's difficult to debug
Code:
etc..
I could not understand.Hw config is okay.No red line (no error),but SF led is continuously lit.And When I load FC100 to plc ''unable to copy this blok'' message shown.
  • FC100.pdf
I've come across a similar obtuse message "cannot load block...." before and it has been due to the block concerned referencing something the CPU does not support e.g. a counter/timer/M flag/block nummber above the range allowed for the CPU.
Does the CPU support SFC14/15?
Is there enough memory available to load the block.
The manual indicates that you need an 8MB MMC card - is that what you have fitted?
Eureka! I used flag addresses in the FC 100 block has exceeded the limits.Because up limit was MB255 for CPU 314.Every things ok.
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,500
Hi guys, i am sorry to asking you this question. To day i was trying to go line to s7 300 plc via ethernet but i am failure.At first i put...
2,709
Hi I want to ask several questions. 1- Is it possible to make communication between two s7300 plc via ethernet, WITHOUT hardware download? Plc...
3,495
Hi, I want to know if the standard of communication ethernet of plc S7 300 and S7 400 it is the same. a driver for read / write date (input...
5,904
Hello, Can somebody tell if there is a way to communicate directly between an S7300 CPU with an CP343-1 Lean ethernet module and an Imaje 2000...
4,444
