Ethernet Problem
siriusblack
May 2011
Laguna
We are Ethernet Card QJ71E71-100 to serve as a link for our data collector. After installation and proper configuration it can not seem to work. The [SD] LED does not blink. We already followed the procedure listed in the troubleshooting guide but everything fails. There are no PLC or Ethernet error being shown in the diagnostic. When the LOOP check was performed, it was able to show the IP address we have set. But when we perform the PING test, there's no response. A laptop was also connected directly to the ethernet card and perform PING test but it prompted "desitination host unreachable"
What seems to be the problem with the card?
When you see "desitination host unreachable", check your subnet masks and IP addresses carefully. Somethings wrong with them.
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
536
Hello I have a two controllers 1756-L61 and I would like to add an Ethernet Card module of one controller to the other one. When I search for...
885
Dear All, I wanna get the data from ind331 indicator(Mettler toledo) to SLC 5/05 CPU via Ethernet Ip using EEM instruction. The CPU=1747-L553...
2,175
Hello there. I have bougth a SMC EX260 SEN-1 ethernet/ip slave and i want to control it from windows PC (with Modbus TCP may be?). Is it possible...
1,002
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,615
