Ethernet Wireless Connection - OMRON CJ1 PLC's
castro
Jul 2004
Brampton, Canada
Currently we have setup a CJ1H-H CPU65 with two CJ1W-ETN11 units (ethernet units) and a CLK21 unit (controller link unit). It is connected via a wired Ethernet connection to a PC and to a CJ1G-H CPU42 (with Ethernet and controller link units) via a wireless Ethernet connection through two LINKSYS 2.4 GHz Ethernet bridges, one at each side of the connection. This connection is critical for the operation of a rotating drum which is part of the machine. We have started testing with another part of the machine which involves 48 other wireless devices and in the future there will be 120. We have had interference problems. Any suggestions about wireless devices which can offer a secure connection ?
Tough one.
Unfortuantely, almost all wireless communications methods are highly subject to intermittant dropouts. No matter what method is used, I like to have slave processors on each side of a link, do most control locally, and buffer commands in and out.
RF solution dropouts can occur because of just about any kind of electrical noise. The ultra-fast rise time on the switching waveform of modern AC drives is a typical culprit (yep, they can hit 2.4 Ghz and above). Other problems can be walkie-talkies, portable phones, interruption of line-of-sight via moving parts, even lags in the wireless transmitter/receiver units frequency hopping.
The first thing to try if you must go this route, is ultra-filter everything. Second would be to use more directional, higher-gain antenna's. On the movable section(s), you might even want to look into an array of antennas. That doesn't mean just putting several in parallel, but properly designing a phasing network to maintain proper feedline impedance. Third might be to have redundant sets of transmitters/receivers, but now we are talking real expensive.
Optical solutions (infrared) are generally more reliable, but not with off the shelf components. The best system I've seen for optical transmission has used a large (about 3' diameter) ring of emitter/detectors facing an identical ring on a winding turret. That was a "roll-your-own" emitter/detector array coupled through signal drivers/conditioners to an off-the-shelf mini-IR coupler.
The simple fact of the matter is, for critical applications, I still prefer to use a wired network, even if it is of a much slower speed. RS-485, DH+, RIO, MODBUS, TIWAY (is that still around?) and the other low-speed standard networks are very reliable through slip-ring or slide-plate couplings.
Good luck.
Hi, I have a controllogix PLC cabinet with unmanaged Ethernet switch. I can go online by connecting to the switch via the laptop wired connection...
3,004
Hi All, Has any of you ever used a PC Adapter (Simatic MPI) in combination with one of those serial to ethernet converters like the iwifi or the...
3,549
Anyone know how to setup the SLC5/05 to communicate through the office network (Wireless). Does Rockwell have such tips? Can't find any.
4,087
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,353
What's everyone using for their wireless ethernet radios? Just for a couple remote 1794flex racks a couple city blocks away. We've used Esteem in...
899
