European Directive Question
Ken J
Feb 2005
Mentor, Ohio
82
Any Europeans familiar with EN 80950 : 1992 ?
If so, could you supply a link or some explanation
as to what it entails. I was told that it may be
some low voltage directive, but I need more information.
Thank you.
Standards
Thank you.
Please find the list of low voltage directive as far as I know. This is the International Standards that I use and reference.
DS DS-HÆFTE 1-1 Standards and their relations to EEC directives - Low voltage equipment
DS DS-Hæfte 1-1:Januar 2006 Standards and their relations to EEC directives - Low voltage equipment, (August 8, 2005)
DS DS-Hæfte 1-1:Juli 2005 Standards and their relations to EEC directives - Low voltage equipment, (June 14, 2004), (February 27, 2006)
DS DS/INF 117 CENELEC Guide No. 16 on the implementation of New Approach directives and the Low Voltage directive with respect to the EC declaration of conformity
IEC 62314 Solid-state relays - Edition 1
IEC TR 61000-2-7 Electromagnetic Compatibility (EMC) - Part 2: Environment - Section 7: Low Frequency Magnetic Fields in Various Environments - First Edition
Regards
Sherwin
Hi folks, I have encountered two different plants (Both having Siemens PCS-7 control systems) where the tags/symbols for the Equipment was...
2,074
I am supplying a control system to Singapore. The range of AWG wire size for the main breaker is 3/0 to 500 mcm. How do I put this in European...
2,765
In my experience, most of the control panels I have seen here in the USA require 480 VAC, 3 phase and (typically) no neutral is required/supplied...
3,776
I have a washer/dryer machine coming from Europe which use 400v/50hz/177A. The machines has some heavy blower/vacumm motors that run on 400v, and...
23
6,698
I got a panel in today built in the U.S. and it has Brown wire for 24 VDC + and Blue wire for 24 VDC-. Is this the European standard? I have seen...
17
4,794
