Eurotherm 650 drive to AB753
tristan860
Mar 2023
Texas
We are changing from an old Eurotherm drive to an AB753 and I have a few questions.
Seems like the 753 has less I/O's on Port 0 in comparison to the Eurotherm Port. Can we still wire directly or do we need extra ports?
Do we need to change our program inside the PLC since most of the programming was on Eurotherm drive itself?
I attached a picture of how the Eurotherm was wired.
Thanks in advance, Everything seems way different.
If this is the drive I'm thinking of, you can do quite a lot of setup in there. You'll need the DSE lite software, a USB-serial converter and a serial-RJ11 cable to talk to it. The operator panel is connected by the RJ11 port. The software should be free, but a quick google shows the first few websites are charging for it. It's basic but easy to use and is similar to FBD, but there's quite a few pages of setup options to go through with PID blocks, mathematical functions, timers and such.
If you can't get hold of the install file, I'm sure I've got it somewhere.
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
43
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,094
I'm just needed the iTools to configure the settings using RS485. Unless I read it wrong it is FREE for just that purpose. I went on Eurotherm...
604
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
513
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,310
