Eurotherm 690 Drive Programming
I used some Eurotherm/SSD/Parker drives a decade ago.
I really enjoyed using the function block programming, it was basically an embedded PLC.
I've done some work with these on old systems. Can't say I enjoyed it; there were a number of idiosyncracies to contend with, but maybe it's just bias from being used to AB drives.
The customer is wanting to replace the Eurotherm with an AB750 drive. (Whenever they can get one). It appears the larger challenge will be learning how the Functions in the Eurotherm drive work, rather than generating a program in the AB drive.
I've just them before, they use software called DSE lite and are programmed through a serial to RJ11 cable.
I found the blocks quite intuitive to use and they can do all sorts of things with the internal logic.
The 690 could master slave and had very tight control. We used them on web handling lines back in 2005.
The 750 family will do thr job fine . You will need dual encoder card and probably a local I/O card. The master slave setup isnt to bad once you get the gearing swtup in the deive itself.
I have just finished testing some panels and have attached the devicenet and logix files Apart from rung comments etc is there anything i am...
3,767
Has anyone ever used ControlLogix with Eurotherm 690+ drives on ControlNet with a 1756-CNBR card or Ethernet with the 1756-ENBT card. I am...
4,219
G
3,919
Guest
G
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
45
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,095
