Eurotherm controls 2500 I/O system
Uno
Guest
U
Does any of you guys using or heard about this controller from Eurotherm controls. www.eurotherm.com
We just have one in our plant with our new machine for temparture scanner. It just scans various Temperature probes and annunciates / trips the machine depending upon the set value.
The commissioning engineer told me that its a PLC and it can do more PLC job also.
You have any experience on these product and how good it is. What about the programming language (Easy or process like). I saw it and it looks like process instruction. Realy did not understand it. But he said its one of the easist.
As we are about to order one more machine from the same supplier and he insists for eurotherm products only.
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
43
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,094
I'm just needed the iTools to configure the settings using RS485. Unless I read it wrong it is FREE for just that purpose. I went on Eurotherm...
604
We are changing from an old Eurotherm drive to an AB753 and I have a few questions. Seems like the 753 has less I/O's on Port 0 in comparison to...
1,100
Dear all, we have a couple of SSD 637 servo drives that need to communicate trough easyrider. On the parker website you can download easyrider...
515
