Event Timing in A-B Pico PLC?
valtechdave2
Nov 2013
rochester, ny
with an A-B Pico PLC, can i monitor the duration of an event? ie. start a timer then pause it without reseting until i want to? like the upper input on a Modicon timer starts & stops timing, and the lower input resets the timer.
Hi
From memory I think not, I don't think you have what is called an rto timer in Allen Bradley plcs. The pico is a smart relay that I think Allen Bradley get someone else to make under there name.
Donnchadh
i was afraid of that. the manual talks about a HTxx "Stop" coil, tried that but it seemed to act the same as a RTxx "Reset" coil. but thank you for your reply :)
P
There is a question to all audience. There is Allen Bradley SLC 05/5 I need to store time how long event, let say some fault, last. It would never...
3,389
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
74
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
298
This may be something obvious that I could learn if I sat down to understand the topic in detail with tutorials and manuals. But sometimes it's...
137
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
503
