Exor RS-485 Communication issues.
Sprayman
Jan 2020
Chicago
50
Hi all,
I have been having a frustrating time communicating between my esmart04 HMI and my Productivity P1-540 PLC.
Currently, I am simply just trying to see any sort of communication between them using some simple read/write commands.
I have attached images to show my settings.
I have done RS-485 comms on the Exor before and have not had any issues.
I even copied a setup where this works to my setup and it did not work.
My DB9 wiring is pin 7/8 -> TX/RX+ 3/4-> TX/RX- and 1 -> Gnd
I am at my wit's end here. Any advice or suggestions would be amazing.
I can provide any more info as needed.
Thank you.
Exor RTU Settings.PNG Exor Tag Data.PNG PLC Address settings.PNG PLC Modus Settings.PNG Exor Wiring.PNG
I advise you to download MBPOLL Windows utility ant try to connect this Windows utility so you can check all comms patameter. The tool is inexpensive and it even has an evaluation mode. You could even download sone serial sniffer if you cannot connect MBPOLL
I'm not proficient with Exor and Productivity, but looking at picture "Exor RTU Settings.PNG" I've seen that you have selected the speed that can be used only with 4-wire/full- duplex and that is possibility that usually equipment does not support. Also I would try to lower number of blocks that are transmitted.
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
102
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
131
Maybe I am a bit thick, but I spent ages trying to get the Combo Box in Exor JMobile to work, turns out that there is a trick that doesn't seem to...
641
Any users/experts out there? I have just spent the last while trying to make an animation property work. This project has a series of images...
1,543
Newbie question for an EXOR Jmobile javascript problem. I want to access at least one of the system values, but I am stumped on which javascript...
1,701
