Exporting routine from v. 24.01
Mar 2018
detroit
Hoping you all may be able to steer me in the right direction (disclaimer: i'm not a plc programmer). Some of our guys using v. 24 on a WIN 10 x64 machine cannot export routines, but the issue is not consistent. I have installed it on several machines and it works but others, with the same configuration, it does not (the save dialog box will not appear). From what I gather, Rockwell will not support v24 on WIN 10, but what is odd, it does work on some machines.
I've installed some VM's with WIN 7 for some folks, but that has it's own set of issues (basically, they don't like it.)
Keeping the machines on WIN 7 is not really an option, as corporate directive is to upgrade all machines to WIN 10.
I have had limited success in the oft recommended uninstall all rockwell and reinstall, but was wondering if there were any settings I could check or any workarounds anyone is aware of to get exporting routines working in v.24 on win 10?
thank you!
DISCLAIMER: I can't answer your questions about why "some work - some won't" ...
but here's something that I'd try first if I were in your shoes ...
install version 24.04 (instead of version 24.01) and see if that helps ... there were some "issues" with 24.01 that were SUPPOSEDLY corrected with 24.04 ...
another "work around" that SOMETIMES works - is to do a "Save As" operation (instead of just Save) and set the file type as .L5K (instead of .ACD) ... L5K files are usually more "flexible" to deal with when it comes time to change from one version to another ...
if none of this helps, you might want to provide more detail about your statement:
personally I'm not 100% sure that I know what you're trying to accomplish ... I'm assuming (gosh I hate that word) that you're trying to save the ACD project files ... the more detail you can provide in your questions, then the more detail we can provide in our answers ...
on another subject:
let's don't get started on the horror stories involved with that particular subject right now ... let's just say that there are some corporations (names withheld to protect the guilty) whose maintenance departments have a secret stash of computers hidden away from the IT department's prying eyes ... some run DOS (with a REAL honest-to-goodness serial port) ... some run Windows XP (and support PCMCIA communications cards) ... and so on - and so on ... for now, let's just say that some "corporate directives" need to come to grips with "reality" in order to keep the company's machinery running ...
welcome to the forum ... hope this helps ... good luck with your project ...
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
324
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
506
Can anyone tell me how to export tags from PC Worx to a .csv file?
330
Hello Everyone, Happy 4th of July to my neighbors! Is there a way to edit Alarms in Excel? The native export is XML, and there is always...
823
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
623
