Extracting Data from Factory Talk SE to PLC
joelryan22
Aug 2017
Ohio
Hello,
I currently have a factory talk project (Project 1) that uses visual basic to calculate an integer. I am in the process of developing a new project (Project 2) in factory talk that also needs to use that same value. The Visual Basic code to calculate this number is very involved and cant be easily transferred from one program to another.
Is it possible to write the value from the Project 1 to a plc so that i can have that value available to use in Project 2, or any other project in the future, without having to port the visual basic code?
Thanks for any help!
Yes you should be able to do it. I haven't used FT SE for a while but I think what you need to do is to use Device Tags for this. A Device Tag is a tag in the FT SE project that is mapped to a tag in the PLC. Write some VBA code in your FT SE project to put a value in your Device Tag. This value is now stored in the PLC (in the PLC tag that is mapped to your FT SE Device Tag). Then create another Device Tag in your 2nd FT SE project that is also mapped to this PLC tag. Hope this helps.
Hey all, I've got an array in a Control Logix program that has initial values in each element of the array. I want to extract these values from...
1,958
Does anyone know how to get a status bit out of a AB SLC500 plc and provide it to Excel??? Can i use ODBC? Does anyone on have an example of...
5,241
I am attempting to access HMI tag properties (Description, Minimum, Maximum values) to populate a numeric input. Is there a clean way to do this...
374
Hi all, I have a customer with an FTView SE system running some datalog files. They can see the trends on the client, but they now want to...
2,711
Hi, I'm using the 2080-MOT-HSC High Speed Counter plug-in module with a Micro850 (2080-LC50-24QWB) using the HSCE instruction. The encoder is a...
1,665
