Extracting FTView SE datalog files to CSV
ASF
Jun 2012
Australia
3,921
Hi all,
I have a customer with an FTView SE system running some datalog files. They can see the trends on the client, but they now want to extract the raw data to CSV (or similar) so that they can import it into their software and analyse it.
Is there a simple way to do this?
Easiest way is to have all the required pens on a trend page and make sure the option "allow export trend data" is checked on the properties of the trend page is selected.
This way allows you to select the start and end times etc.
Alternatively use the FactoryTalk View File Viewer application and open the log files then export.
This way is painful depending on the archive structure - data log files changing daily,monthly etc.
I think that datalog files can be to a DB like SQL just needs setting up, then these can be exported in something like Excel, years ago I did an RS32View system (I do believe FT is nothing more than an upgraded version of this, it is so similar), we initially logged the data to MSAccess DB's, but as this was being dropped and not liked by IT we just logged the data to an SQL DB on the servers, I wrote an application in Excel VBA for production to produce reports.
Just circling back to this job now - thanks Chelton, it worked just as you described.
I am attempting to access HMI tag properties (Description, Minimum, Maximum values) to populate a numeric input. Is there a clean way to do this...
377
Hi, I'm using the 2080-MOT-HSC High Speed Counter plug-in module with a Micro850 (2080-LC50-24QWB) using the HSCE instruction. The encoder is a...
1,666
Hi, I am having trouble getting the .dmk file extracted so that ControFlash will see the new firmware revision. I hit extract all files and it...
4,790
Hello, I currently have a factory talk project (Project 1) that uses visual basic to calculate an integer. I am in the process of developing a new...
1,327
I have a stand alone test stand that spits out a ASCII string with the test results. Each results in the string is separated with a comma and...
1,842
