Factory talk studio Me help needed
stu
Aug 2005
England
783
hi guys I hope your well and had a great xmas
I have got something confusing me on factorytalk me,
I have an issue where I would like a pop up or a banner to be activated if two buttons are not active
ive tired to work out expression but get an error?
I have a silo selection Tag {HMI\F34:18}
and silo button 3 confirm Tag {HMI\B35:2/2}
which I would like to put a banner to remind the operator to confirm the buttons on
so thought I could do an expression to activate the banner
IF {HMI\F34:18} = 3 & {HMI\B35:2/2} =0 then activate the visibility
but cant get to work and ideas
thanks stu
A quick and dirty way around this is to create two compare instructions in your PLC program that activate a coil.
So when F34:18 equals 3 and B35:2/2 equals 0, then activate coil B3:1/0 for example.
Then set your visibility to activate the banner whenever B3:1/0 equals 1.
Can you post the full expression? I presume the THEN/ELSE elements of the expression are declared?
See my example below;
If ({[PLC]R17_ControlDint[0]} > 0) AND ({[PLC]R17_ControlDint[0]} < 40) Then 1
Else If ({[PLC]R17_ControlDint[0]} >= 40) AND ({[PLC]R17_ControlDint[0]} < 100) Then 2 Else 0
Just another point, i normally use NOT to evaluate bit level addresses rather than BIT=0 or 1 as you have it. May make no difference whatsoever, just sayin'!
Regards,
Rob
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
177
I have some global objects, numeric display with associated data that pulls up a pop up screen. for the life of me i cannot figure out how it...
240
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
374
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
688
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,320
