factory talk studio pop up screen help
stu
Aug 2005
England
785
hi guys
its been a while since I have had to think about factory talk studio,I have been ask to put an acknowledge pop up screen on a pvp, what they want is , if a recipe is changed we get an input into the plc to latch the pop up page to open to make an reminder to check the silo, and then on the pop up we will have a reminder message and a accept button which will unlatch the pop up screen , but Im a bit stuck on how to go about it , have you got any ideas that I could try thanks stu
Hi I have just tried the global connection remote display and I have used a mov instructions to call the screen in the plc which works but when I press the confirm button it changes in the plc but I can't get the pop up to dissappear it stays on the screen even if I move another display number into the remote display ?? I have even tried to close all pop ups can anyone help I'm nearly there ?? the plc im using is micrologixs 1400
I think you need a macro button (it has been a long time since I programmed a PV+) so you can write a macro that does two things:
3. Set the confirm tag in the PLC
2. close the pop-up display
I have done it without a macro - I just set a bit in the PLC, and the PLC turns off the bit and closes the popup.
One thing that caught me about the "close popup window" global connection is that it's not a boolean tag that, when turned on, closes the current popup window. It's a numeric tag, and when you send it a number other than zero, it closes the popup with that display number only.
Although it's odd that your "close all on top displays" global connection doesn't seem to work...
To hazard a guess, I would suggest that your popup is set to be always on top. The "replace display number" only changes the display behind your popups, i.e. "replace" type displays. Another semantics gotcha, it's not a command to replace the display, it's a replace type display number.
edit: also, make sure you understand the difference between the "remote display number" and "replace display number". Another semantics thing that always trips me up ;)
have you got an example that I can see this may me easier ? ive been trying to do this on night shift but no joy thanks for your help guys
I have had a thought rather the getting a screen to pop up I have created a panel with a viability tag trigger had to remember first thanks again good people
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
183
I have some global objects, numeric display with associated data that pulls up a pop up screen. for the life of me i cannot figure out how it...
242
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
380
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
695
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,327
