Factory talk tag use to Wonderware?
They aren't in anywhere near the same format, and have far different attributes, so I'd guess that is a no.
It might be possible to write a parsing program to manipulate the export file into a valid DBLoad import file, but I've never done it nor looked into it.
Yes the macro takes takes the export from factorytalk and modifies the data and location to match WW import file.
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
309
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
406
Hello, Which syntax I need to use for write on value on a “local tag” that have “Machine” as scope? Thanks
453
Hi , i currently have data logs running but i need a way to link a tag to them so if there ever not running i can trigger an alarm? what is the...
1,859
Hi, We have added some new valve timing functionalty to AB programs and are running it out across 6 units. I have verified that the code works...
2,010
