Factory View can't see offline tags
amberman
Jun 2014
Brighton
104
I'm unable to see the offline tags of my PLC program via the FactoryTalk Tag Browser..
From Google searches I can see this one has reared its head a few times but I'm missing something more fundamental than the solutions I've found. I'm not familiar with FactoryTalk View and have so far only commissioned equipment and not written anything from scratch.
The problem seems to be that I can't save the location of the offline tag file that I've chosen in the Communication Setup. There's no "Apply" as the Help says there should be and when I click OK it just closes the box and I find that nothing is there when I re-open it. Any ideas or is there an idiots guide to setting up an offline link to the PLC software?
Once you have chosen the file the 'Apply' next to the link name in the upper left should be enabled. If you see that click it then choose 'OK' at the bottom.
I choose the file, click Open, it appears in "Offline Tag File" but the Apply at the top left stays greyed out.
Turns out you have to manually add a processor to the Runtime (Target) Ethernet tree and the offline tags must be on a local drive.
153
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
350
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
303
I have a factorytalk view studio 6.1. But all my runtime files are 5.1. I have installed factorytalk view studio 5.1 But whenever I try to...
874
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
625
