FactoryTalk: Adding a Combo Box
smohamed
Mar 2008
ON
108
Afternoon everyone,
We're working with FactorTalk here (FactoryTalk View Studio) and running FactoryTalk View SE (Client and Server pair).
On one of our screens, we would like the ability for a user to select one of four options using a ComboBox. Based on the selection, we can then write to a tag to use in our database. This is where we're having trouble.
However, being new to VB I have been having some difficulty. I've looked into some scripting but haven't been to successful.
I've gotten as far as adding the combo box, but have run into a bit of a wall in terms of adding the pre-list items. We've used the commands ComboBox.AddItem but that doesn't seem to work.
I apologize for my description, as my terminology is probably incorrect, but I am looking for some examples that I could start with to get us on the right track.
Thanks in advance
If I understand your question correctly, I believe you might be looking for the Control List Selector. If so this can be found under: Objects / Advanced / Control List Selector.
Hopefully this might help you.
Hello, I am having issues with adding users to FT Admin Console. I have never had an issue with this before. As I am able to add the user...
597
Hi, i've finally start to play with Historian and unfortunately stop on the beginning. I can't add a simply tag from my PLC. I read similar...
21
17,045
Hi all, I have had zero experience with PLCs but have started to work on an unfinished project. The control stuff such as RSLogix 5000 and...
17
17,836
Has anyone added IP Cameras to a FactoryTalk SE application? I was hoping there was an easier way than using ActiveX and browsing to the Camera...
5,701
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
34
