FactoryTalk alarm sound in network configuration
vas2006
Dec 2011
Krasnoyarsk
Hello, PLC guru,
it would be great if someone will help me.
We have a project with two FactoryTalk servers (redundant), and two clients.
All alarms are set as HMI tag alarms, not FT alarm and events. When the alarm occures, the system tries to play notification sound from server sound card. As server is not equipped with sound card, so beeper is activated instead.
But we need sound is to be played from client PC sound card (server is far from operator room). I think I could use Events for detecting and PlayWave command, when new alarms occures, but maybe other built-in way exists?
I suppose that such a task is very frequent and trivial, but so far can not find a solution.
Thank you in advance.
Dear Memners, i have an issue regarding factory talk view alarm sound, i have set internal bell for sevarity =1, internal speeker are working fine...
2,143
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
144
FactoryTalk View ME running on PanelView Plus 7, connected to Compact GuardLogix 5380 PLC Customer is asking for a physical push button to be...
187
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
199
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
345
