FactoryTalk Gateway setup for OPC UA
Maestrom38
Aug 2017
Grenoble
Hello all,
In a current project we are trying to connect an R.A PLC (CompactLogix) to an OPC UA client/server.
To do so we first installed RSLinx Classic Lite on the supervision machine to setup the DDE/OPC connection with the PLC, which so far seems to be okay.
The second step was to install FactoryTalk Gateway locally on the supervision machine to connect to the OPC (server?) configured with RSlinx. But here is the issue, even though FactoryTalk Gateway is able to browse the PLC on the network, it can't connect to the Topics OPC Topics created in RSLinx.
I tried to configure FT Gateway in Local or Network via the configuration console but nothing appears on the list.
Does anyone already used and configured FT Gateway ?
PS: On the FT Gateway Configuration console we have the following error : RSOPCGateway.xml configuration file error.
Thanks by advance,
Greg
With FactoryTalk Gateway we use RS-Linx Enterprise (not to be confused with the various flavors of Classic) for connection to the Control-Logix and Compact-Logic processors. In this scenario FT Gateway is the OPC server.
RS-Linx Classic Lite does not have OPC server capability, and I do not know of a way for FT Gateway to use Classic Lite for OPC services. FT Gateway can provide OPC through one of the Classic OEM or higher, which require paid licenses.
If you have FT Gateway and do not need OPC services to legacy processors (e.g., PLC-5), then RS-Linx Classic is not necessary; you only need RS-Linx Enterprise, which comes with FT.
Hello Everyone, I'm using Factorytalk Linx Gateway V6.30 with Nov 2022 patch in order to publish tags from a network distributed FT system to...
922
Hello. I need to support a customer who is developing a custom OPCUA client that needs to read data from CompactLogix using the FactoryTalk Lynx...
1,446
Hello all, I have what has become a complex problem, with what I'm hoping is a simple answer. I am using FactoryTalk Linx Gateway set up as an...
2,381
I tried doing this by adding a remote opc server running wonder ware on an Opto22 controler using ethernet. The topic comes through and is active...
2,127
Hi everyone. I am a noob. I have looked at Rockwell's literature and searched the web a bit, but I still do not have a basic understanding of...
8,609
