FactoryTalk Linx Browser
BeepBob
Jan 2023
Oakland, CA
107
Hello all,
I have an issue with Factorytalk Linx browser.
The browser is in read-only mode due to nobody log on. I can't add a driver.
I pressed log-on and type in the admin username and password.
And I get the message " unable to log on user" from computer < TestA > " There is no account for this computer < TestA > in the network directory.....
My confusion is: This Factorytalk linx browser is being run on a workstation <TestB> that I remote desktop into, why is it trying to validate the credential I just put in against my local computer <TestA>? The computer I am using to remote desktop into the dev environment has nothing to do with Factorytalk
It makes no sense?
Sounds like you might have a configuration issue with FactoryTalk Directory.
Try reconfiguring using FactoryTalk Directory Configuration Wizard.
You might also need to "Repair" your FactoryTalk Services Platform.
I don't remember all of the specifics, but when you remote in to another computer, it still acts as though you are on the main computer as you are experiencing. You will need to add <TestA> to the FactoryTalk Directory on <TestB> in order for it to work. You will need to do this for subsequent machines that might be remoting in to TestB.
There is a KB article about it, but you need a TechConnect contract to view it: ID: QA7701 | Access Levels: TechConnect
Hello I have an emulator SoftLogix on VM1 and running FTView ME on VM2. I am trying to link the two by setting up a short cut inside FTView but...
2,144
What is the difference I assume FT Linx is just newer but can RSLinx be used with Studio 5000?
6,763
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
107
Hello all, I have an issue where RSLinx classic can see a PLC just fine. But when I use FactoryTalk Linx Browser to browse to the same PLC it...
863
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,592
