FactoryTalk ME global objects and parameter files
dmned64
Jun 2013
Florida
99
I the past I have successfully used both global obects with parameters and also popups that reference parameter files. I am trying now to use multiple instances of a global object on the same graphic and have each instance reference a parameter file instead of filling in the global object parameter entries for each instance. One reason I want to do this is so I can also use a single instance of the global object on a different graphic that would also refence one of the parameter files. This way I can enter the information in the parameter files once then reference it each time I designate in a use of the global object.
Can this be done?
Yes. That is usually my preferred way to use parameters too.
OG
What is stumping me is when I place the parameterized global objects on the graphic I cannot see how to link each instance to a different parameter file. I know how to do it if the graphic is a pop-up with a single instance of the object but not when the graphic is not a pop-up and has multiple instances of the object each with a reference to a different parameter file.
Hello all, I am working on a project in FactoryTalk SE. Suddenly while working on a new screen, the global objects I am copying to it are not...
1,271
Hello guys, can anyone help me with FactoryTalk View Studio. I need to use a Global Object that contains VBA Macros in different displays, but it...
1,677
I have a FactoryTalk ME application with some global objects for diagnostics of 1769 and 1719 IO modules that don't work. They were developed by...
1,910
Hi all, Does anyone know of a way to pass global objects a parameter file name as a variable? e.g passing {#101} or the like to the to...
1,316
I have a similar question to a previous post but thought it warranted its own thread. I have a global object (primarily acting as a goto display)...
1,556
