I the past I have successfully used both global obects with parameters and also popups that reference parameter files. I am trying now to use multiple instances of a global object on the same graphic and have each instance reference a parameter file instead of filling in the global object parameter entries for each instance. One reason I want to do this is so I can also use a single instance of the global object on a different graphic that would also refence one of the parameter files. This way I can enter the information in the parameter files once then reference it each time I designate in a use of the global object.
Can this be done?
Can this be done?
