Factorytalk ME HMI Question Marks all over
michael30
Jul 2017
CA
I have a PanelView 6+ that runs a ME program. Recently, I've had a couple occasions where the HMI graphics has question marks all over the screens. And restarting the panel/system seems to clear that issue up. Any idea of what could be causing this?
Sounds like the HMI is losing connection to the PLC. Indicators which display values read from PLC tags will instead display question marks when failing to read the value. Things like multistate indicators will have a set indication for a failure to read as well, by default showing 'Error'.
The question marks means that the PV cannot get the data from the PLC. This would mean either there is an error in the tag name or expression, or a loss of communications.
Since it does not always show the question marks we can probably rule out an error in the expression/tag. It is most likely a loss of communications. I would begin by inspecting the connections either at the PV, the PLC, or the switches.
OG
Had the same issue a few months back. Suggested multiple possible issues and corresponding solutions. Boss's answer was to install a toggle switch to cycle power to the HMI. (On restart, the HMI tries to establish comms.) It worked ... keeping the line going until the place shut down.
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
346
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
110
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
498
