While this is something you can do easily in View SE, View ME makes this a lot harder. It would require some work in the PV and some work in the PLC. We will have the PV send a unique number to the PLC for each user. Then we will have the logic in the PLC look at that user and force a specific display to open.
- Create a tag in the PLC that we can use to store a unique number for each ME user. A DINT tag would be fine. I'll call mine PV_USER. The PanelView will write to this tag.
- Create a macro in FT View that writes the unique number to that tag. You would need to do this for each user. If you've got 5 users, you'll need 5 macros. 30 users, 30 macros.
- In FT View under Runtime Security assign those macros as the Login Macro for each user
So now, your PLC will know who is logged in by looking at the value in that tag. If you have categories of users, you can identify them by category instead. Perhaps I have 30 users, but they fall into three categories. Maybe a several maintenance users, several operators, and maybe a couple engineering users. Operators, I assign a 1, Maintenance, I assign a 2, and Engineers, I assign a 3. So I end up with just three unique numbers instead of 30. But you still need to create a macro for each identified user.
- Identify which displays you would want to appear for each user.
- In FT View open each display and access the Display Settings. Assign a unique Display number to each display. Do not duplicate the numbers. Use any number from 1 to 65536. They can be used in any order, but I generally start with 1 and work my way from there.
Now we have given each display a way to be uniquely identified.
- In your PLC, create a DINT tag that we will use to control which display appears on the PV. Maybe a DINT that we call SET_PV_SCREEN
- Write logic to look at the PV_USER tag and MOV the correct display number to SET_PV_SCREEN
If your logic puts a 5 in that tag it will force the PV to go to that specific display. For example, If PV_User = 1 Then MOV 5 to SET_PV_SCREEN.
Now, if you leave that number in there, they can never leave that display. So you will probably want to include logic that resets the SET_PV_SCREEN back to zero after a moment. A zero in the tag allows the user at the PV to control which screen they want to view.
Hopefully someone else can chime in with a much easier method. But I think this is the way you would have to go. Or, include a Goto button
OG
