FactoryTalk user login
andy_1983
Mar 2018
uk
76
I’m converting a panelview 550 to a panelview +7 application, operating with an SLC5/05
Is there a way a could drive a bit in the SLC from the panelview depending on a particular user being logged in. ie I want to tell the SLC if there is an engineer logged in, an operator logged in, or no one logged in (both previous conditions logic 0). I’ve set up user accounts for engineer and operator with the required passwords, and have set up security on each page.
I can see a way of doing this by having a passcode on a numeric input, and an EQU block in the PLC, but it would be nice if I could automate it from the user log in.
I’m using factorytalk view ME V9. And Pv+7
Thanks for any help
Andy
You could use the Remote Macro. You'll find it under Global Connections>Macro tab.
1. Create a Macro named Macro1 where SLC Tag = 1
2. assign the expression to CurrentUserHasCode() . enter security code Letter in the ()
Thanks very much, I’ve managed to sort it out as per your help. A bit more learnt about Factorytalk too!
Thanks again
Andy
Yup, use a Macro to write to a PLC tag based on the state of an HMI tag.
I've used it two different ways.
One, to set a single BOOL bit for each user with one HMI tag. (If USER = "logged in" THEN B*:X/Y=1, ELSE 0)
Two, an INT tag set to a different value for each different user. N*:X is 1=operator, 2=tech, 3=engineer, etc... Set an HMI tag for each access level, and write the corresponding value to the SLC location.
Hi every body. We have an windows based HMI installed with factory talk SE studio in which we have copied our previous factory talk backup. In...
4,628
Hello is their a way to create a password that contains the following variables: 1) number of the day in the month, example 07 the 7th day in...
733
I've got a problem that's been annoying me for a bit. My users are set up in ftvme and when I run the runtime on my computer I can log in fine as...
1,815
I have a FTView application that allows user management via the HMI. When I need to make a revision to this application, I upload and restore the...
812
Hello Experts, I m trying to create runtime users in FactoryTalk View ME 10.0. I m able to create runtime users, able to add them in existing...
1,284
