FactoryTalk ME Sending The Same Tag Value To Different Nodes
MarkNightingale
Sep 2010
In The VAT Shed
740
I have 6 fillers, which all run the same. I want to send a value to the same tag address in each of the fillers using FactoryTalk Studio ME.
So for example if I write a value of 60 into the ME Tag ST2_Caustic_Wash_Time, then this goes to each of the fillers tags.
{[PLC31_Filler1]Data_From_HMI_Filler[127]}
{[PLC32_Filler2]Data_From_HMI_Filler[127]}
{[PLC33_Filler3]Data_From_HMI_Filler[127]} and so on.
I have read that I can use a macro but I haven't really used them before, and from reading the manual etc, it seems a long winded way to do it, because there are about 50 of these tags, so it would mean a whole load of work.
I don't know if there is a Tag group, where what ever value is in one tag it will write the same to all the tags in that group, which is basically what the macro will do.
Any help would be much appreciated.
Mark
The Macro is the way to do it.
Macro files are just text, so you can edit them with anything you like: fast and easy.
Exactly how many PLC's are you sending the data to?
Two or three, I **might** use a macro, but still probably wouldn't. I'd write the data to one PLC, and have that MSG it over to the others instead.
First Attempt
Ok, so I haven't used macros before.
This is what I have done for the first timer.
Now I have opened the .mcr file using excel so that I can easily edit the macro, and it goes back into FactoryTalk and the changes I have made are there.
So the real question, is this the correct way that I am doing it?
Mark
  • Macro.zip
I am sending it to 6 PLC's and I thought about doing that or even sending all the data to the main PLC and then have that send the data to all of the fillers.
Mark
Hello all, I seen some post here from 2013 regarding sending text messages for alarm using FactoryTalk ME. I wanted to see if anyone implemented...
2,015
Hello everyone, I'm using PVP1000. How can I send e-mail when an alarm occurs in FactoryTalk View Studio? And the other question I wonder...
2,259
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
155
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
