Factorytalk SE Alarm summary filtering with VBA
Aug 2017
Wisconsin
25
Hello,
I am looking to use the same header on every page (global object) that has an alarm summary button on it that will go to a display with an alarm summary. The problem is I want to do filtering based on what screen they pressed that button on. I am fairly confident there is a way to do that using VBA, but I am very green with VBA. I have found that the following in VBA will change the alarm summary filters (AlarmSummary.FilterName = "Packaging"). I have all the filters built out in the alarm summary I just have to select the correct filter based on the screen they click from.
Thanks,
Derek
I believe I have found a manageable way to achieve this (If the following is possible) Does anyone know of a way to read the parameter definition of a global object on the screen into the VBA? looking to use the VBA I mentioned in the first post (AlarmSummary.FilterName = "PermPack") but use it as (AlarmSummary.FilterName = "Current screen parameter definition #2". Then I can put in the alarm filter I want per screen into the parameter definition of the global object header.
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
446
Expert, Could you advise me some idea how to add tags in Summary Alarm's FilterDefinition? SumView.FilterDefinition = "AlarmShortName LIKE...
913
I have a issue with my alarm summary/banner where it losses connection to the Alarm Server. It's kind of weird because when I click on the server...
1,351
I have the issue where the HMI alarm summary viewer on the screen is automatically clearing the alarms after 2 days, not all of them just any that...
1,554
hi all, I have the issue where the HMI alarm summary viewer on the screen is automatically clearing the alarms after 2 days, not all of...
1,080
