Factorytalk Trends - some way to start and stop?
James Fillmore
Sep 2004
Detroit, MI
45
These PanelView Plues ROCK except for the trending. UGH.
I'd like to monitor the scaled output from a loadcell over a short, say 2-5 second time window and then FREEZE it.
There appears to be no way to do this.
Any help?
That must be one of the 1st times that this has been posted.... the latest I heard was Factory Baulk.
I don't find the trending too bad, especially for a touch-screen anyway. The 300,000 point limitation is my main gripe, as depending on the no of pens/sample rate, the history is limited.
I'd like to monitor the scaled output from a loadcell over a short, say 2-5 second time window.
There is the option to change the X-Axis to seconds, so you could set it to 5-secs.
and then FREEZE it
There is a Pause Pen button, Objects/Trending/Pause.
Of course, 2-5 seconds is extremely fast, and catching xx points within this time would depend on how fast your model is setup for. The faster your sampling rate, the less of a time-frame that you will have (based on the 300,000 limit).
You can log to a network drive also, but I have not done this yet, I do think that the limit is still applicable, but you would have the facility to copy the files away somewhere else easily.
Hi, Does anyone know if it is possible to start the trends the moment the hmi starts? Now I enter my mainscreen, but the trend only starts...
3,171
We often use Panelview HMIs where Allen Bradley gear is specified, and I've always been frustrated by the lack of functionality offered for...
123
I have been struggling with something for the better part of a week navigating the ins and outs of (as far as I can tell) poorly documented...
581
Hi all. I'm a uni researcher using FactoryTalk Studios SE (just basic knowledge). Have some previous experience with Factory View32 years ago and...
640
Hi All, Is there any way to make trending easier for the customer? I don't want complexity, just the ability for techs to add pens without having...
689
