factorytalk view 3position Selector SW
nmk34
Apr 2019
texas
80
i need to create a 3 position selector switch, Auto, Manual and Sanitation. Can someone layout the steps in creating this task? I saw a thread on this site but could not follow all the different suggestions.
FactoryTalk View ME
You can create a 3-position switch using the animation function and 3 Interlock push buttons.
First make a DINT Tag, I named mine POS_SW. Use it for the Animation Tag and the Connection Tag for the Interlock push buttons.
The Switch can be found in the Graphics folder/ Libraries/ Buttons-Industrial.
Right Click on the switch and select Animation, set the animation values as shown below.
On the General tab of the Interlock push button set the button's value to 1, 2 or 3.
In your PLC you can use the EQU instruction on your DINT to determine the switch's position. (Auto=1, Man=2, Sanitation=3)
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
115
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
