FactoryTalk View Alarm Setup Messages Deleting Itself
haylow_89
Apr 2017
Ontario
I have entered the messages many times into the Alarm Setup but every time i re-open the alarm setup, every message that has the Trigger Value=1 will be deleted.
Anyone have a similar issue?
Thanks.
Are you re-sizing the screen / scrolling down and pressing the OK button, if you just shut the screen they wont't save.
So I found a work around I suppose.
I just moved everything one row down, the first row for each trigger is a dummy with a trigger value of 99999.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
152
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
206
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
363
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
453
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
566
