FactoryTalk View Custom Login Solution
bfearnow
Dec 2013
Athens
Hey all,
This is my first post so I thought I would share a solution to a request I've seen a few times on this forum while trying to figure it out myself before making an account. (n)
I handled all of the security myself in the PLC, creating strings for usernames and passwords and comparing them to an input username/password from a PanelView. Each username/password combination has its own "permission level" which allows access to certain parameters (like saving to a protected number of recipes which we found useful when operators "accidentally" overwrite working recipes).
The biggest problem for people that I saw was not being able to track when the screen was "idle" in FactoryTalk View. To do this, I still use the auto logout feature in the Project Settings which has no effect on the Username/Password status, but when the autologout happens you can have it move to a screen number. When I am on this screen number for a predetermined amount of time I auto logout of the PLC username/password/permissions. I know its not much for my first contribution to the forum, but I've only had about a year of PLC experience.
If you have any better suggestions let me know!
I'm testing the ability to make a custom ActiveX control for PVP7 applications to be able to write data out in an XML format. With my simple...
652
Hello, I am having trouble configuring my security in FactoryTalk View ME (for a PanelView 300+). We have added several users with the different...
2,464
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
173
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
132
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
179
